Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Sleeping problem with hall effect sensor reed switch
Hi, I have an early 2011 17" macbook pro running bootcamp.
It intermittently goes to sleep without warning. I use various programs to keep it awake by blocking the sleep command but it doesn't always work and it isn't ideal. Have tried reinstalling both OSX and Windows, doesn't help.
I suspect an issue with the lid close sensor - windows is reporting (in the system log) that this is the reason for it sleeping.
So my question is - can I replace or disable the sensor? Happy to just remove it and just manually tell it to sleep or shutdown - the macbook stays on the desk 99% of the time so I don't need to close the lid.
Thanks for any help.
Add a comment
1 Answer
I've the same problem. I ordered a power board for US12 and replaced mine. That solved the problem.
Add a comment
Add your answer
rjoh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 187
