Question Closed
Need Part only - Dgitizer Glass Toshiba Satellite Radius P55W-B5220
Hello, everyone!
I need the Glass digitizer for a Toshiba Satellite Radius P55W-B5220
I see a few Whole LCD digitizer assemblies but all I need to replace is the Glass Digitizer that cracked in one corner, The LCD works and all is fine, just the three inch crack on digitizer and it does not respond!
LCD is fine and I can use the Keyboard/mouse etc!
Anyone know who has one or where I can locate one?
I have searched eBay and all over!
I appreciate the assistance on this!
CG
Add a comment
1 Answer
Most Helpful Answer
http://www.ebay.co.uk/itm/like/182206661...
^Closest available, would recommend emailing seller to make sure it is compatible. Also check for repair videos on your model, to make sure the LCD and glass are not glued together, which will make it a lot more difficult to do the repair.
Score 1
1 Comment:
Hello Reece,
Not but thank you I have a ton of those links that you suggested and they are all for the C Series!
I need the P55W-B5220 Or at least to get close the P55W-"B Series"
Most on the P55W digitizers Glass replacements available as the one you suggested are all "C" series!
I have asked all those with the LCD Assembly as well as the ones selling the C Series about the B5220 or B series and they say they don't have it!!
I am calling HP on Monday to find out if in fact the Digitizer cannot be purchased alone and if it has to be purchased with the LCD together as in assembly! The whole assembly is averaging in prices of $ 225
Thank you
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 298
