Can I fix the mainboard?
I was trying to remove the battery of the phone to get to the display and accidentally popped off a surface mount component with the spudger. I think it might be a diode and it doesn't look broken, I believe a dot of welding would fix it. It was fixed right below the back camera, on the left side. There are two of them side by side, easy to see.
Is is possible? How would you do it?
2 Comments
Nicolas Caycedo there are a few component and your description of the location is not enough to identify your component. Use this guide Adding images to an existing question to post images with your question. that way we can see what you see.
by oldturkey03
Thanks for the guide! It's not easy showing such small components in detail, I hope they are clear enough :)
by Nicolas Caycedo
