Can this TV be repaired
Symptoms:
About a year ago, Sony Bravia 52" model KDL 52V5100 TV screen would occasionally be filled with vertical colored lines when turned on. Turning it off and then back on would usually make the lines go away and screen would be normal.
For the past year the TV was completely normal.
Recently the picture suddenly became bad but in a different way. The picture is very dark, and the left side of the screen is really blurry. Changing channels the picture is very slow to show the new channel in focus, like its in slow motion.
Best Buy won't repair it.
If the above information points towards a particular failed component I'd like to know what that might be. TV is 8 years old and has a great picture. Hate to throw it away if its just a bad part.
Additional Info added 4/25/17:
Finally removed the back of the TV. Components are:
T-con board
Power Supply Board
Main Board (I/O)
2 Balancers (left and right, located along sides of TV)
2 Inverter Boards (left and right)
Located service manual and did on-screen diagnostic. No error codes are listed.
No blown capacitors are visible. Have not yet removed the covers over T-con board or Balancers. The left Balancer is covered by the Main board.
