Rescue password date attached
Enter rescue password
2015/04/10
2015/04/24
2015/04/10
2015/04/24
Remove the small button battery from your motherboard. This should reset the CMOS chip and alow you to gain access to your system. There is another method which involves bridging some connections. If the first method doesn't work reply to this answer so i can explain how to do it
good luck,
Eric
Thank you , my x553m doesn't have a cmos battery I did press ctrl+r and it will ask you to do enter rescue password I asked a friend he generate code for the date I mentioned above I entered the code and all was good
Thank you for the help
Can you please generate a code for the date 2015/08/03
If your laptop does not have CMOS battery, like X553,
follow this
Hi Eric, I need a password for 2015/08/07. I have no cmos battery either. Please help. David, UK.
I need a password for 2020/07/01
I have the same problem with the x553m I need a rescue password for 04/10/2015 will the same password work for mine?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,429
4 Comments
Um? whats the issue?
by Eric
I forgot my password for the boot bios
by Abe Aoun
hello i have an asus x553m showing password when i switch on the laptop computer immediately and i cannot get into the settinf
by Alpha Sesay
and also these is not cmos battery into the computer. how to reset this password to solve the problem
by Alpha Sesay
