The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Questions View all
Plzzz helppp , will it spread?
Hi guys i just got my m8 and when i turned it on for the first time i saw a bright line on notification bar, its not visible on black but on other colors its visible , specially when you look at it from an angle.
Here are some pics of the issue:
https://mega.nz/#!i9ExGKDL!WN8iXgvxfYMU_...
https://mega.nz/#!fl02jKoL!QDcgbRVqEaB1B...
https://mega.nz/#!K51gwAgS!R2yXJIolTFY-J...
As you can see in the pics its not visible in black.
Should i be worried? Will it spread to other parts?whats ur idea about it?can i fix it?
Add a comment
1 Answer
Chosen Solution
Hi,
If you just got it, it should still be covered by the manufacturer's warranty.
Contact the retailer that you bought it from as ask if you can see another similar model to see if it has the same problem or not. If the other similar model doesn't have the same problem ask the retailer if it can be exchanged due to the fault. If it can, factory reset your phone before you hand it over to delete your private information. and remember to remove the SIM card and SD Card (if any installed) Also take the sales receipt (or proof of purchase), the charger and any other accessory that came with the phone back with you if you can exchange it for another
Some will help and others won't. It depends on the store policy regarding warranty service.
Remember though that the phone is always covered by the manufacturer's warranty regardless of what the store says. You just may have to deal with the manufacturer and not the retailer.
If the retailer doesn't want to help you then follow the information in the warranty statement in the documentation that came with the phone as to what you have to do to make a claim for a warranty repair or replacement.
Score 1
Add a comment
Add your answer
Dimitrif Kritschief will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 40
