Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
antenna feeding and grounding points
What sort of antenna does iphone 4 employs? Is it an IFA (inverted F antenna)? I tried to find the feeding and grounding points, particularly for the wireless antenna (WiFi, Bluetooth and GPS).
Usually and IFA has a feeding point somewhat in the middle. Unfortunately, I cannot find it. There seems to be a feeding point close to the top slit.
Is it possible then to achieve dual-band behavior? How many grounding points are there, and where?
thanks
Score -1
Add a comment
1 Answer
Chosen Solution
jenni, check you other post. Hope it helped. Where are the iPhone 4 antennas' feeding and grounding points?
Score 1
Add a comment
Add your answer
jenni will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 918
