Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Questions View all
Battery drain fast even after replacement (6s)
I've changed the battery yesterday(having the same issue with the one that i had before . Checked with coconutBattery had 92% Life, charged only 150 times .. Battery was good but i had to change to SEE if the Battery was the problem ...But it isnt..Battery Drains in Stand-by .in 12 hours max 10 minutes usage battery drains 70% overnight . No internet connection ..3G not LTE .. trying airplane mode still same... reset no applications installed still draining ...what is the problem? I brought the phone second had but I had warnitiy (I went to apple and said them the problems ..they checked my phone I said no hardware problem .. and it was giving back as i sended..now no warnitiy. Someone has this problem?
2 Comments
The serial number you entered is not eligible under this program because either: - It's not one of the serial numbers in the affected range OR - Our records show that your battery has already been replaced. If you paid for a battery replacement service, check with Apple to see if you are eligible for a refund.
My phone is not turn suddenly down . I've changed battery with a new one witch is better than the original one but still drain fast .. I don't think the battery is the issue
Example: I charge my phone 100 % after 10 hours without touching the phone I have like 30% +- battery left
by
Add a comment
1 Answer
Chosen Solution
I don't really understand what you mean but I only have bluetooth off on my 6S.
Have you tried restoring the phone?
Where did you get the battery from?
There are many batteries out there that are bad aftermarket quality and refurbished batteries (batteries that have been repackaged and the gas gauge board being replaced meaning that these refurbished batteries are really 60-80% battery life instead of brand new 100%).
May want to check this out:
https://www.apple.com/support/iphone6s-u...
Score 3
Add a comment
Add your answer
Daniel Dorneanu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 2,566
