Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3669 Questions View all
MacBook Air 13" SMC error PFM001
Maybe someone can help me.
Sorry for my bad english, i´m from germany
My Macbook Air 2013 13 inch starts with trick: Disconnect battery, hold power and after 10 seconds simultaneously connect the Magsafe.
The hardware test spares the error PFM001 (SMC error)
A new chip I've already soldered, but nothing happens, except the fan turns full power.
With the original chip it works at least with the trick.
Many Thanks
Logfile:
Feb 22 08:22:24 Users-MacBook-Air logd[52]: Time changed, updating file headers
Feb 22 08:22:24 Users-MacBook-Air coreduetd[69]: assertion failed: 16D32: libsystemstats.dylib + 10401 [4FD7934D-2E1C-366D-8B04-725203F4785D]: 0x0
Feb 22 08:22:24 Users-MacBook-Air syslogd[35]: ASL Sender Statistics
Feb 22 08:22:25 --- last message repeated 10 times ---
Feb 22 08:22:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.emond.aslmanager" tried to hijack endpoint "com.apple.aslmanager" from owner: com.apple.aslmanager
Feb 22 08:22:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.emond.aslmanager" tried to hijack endpoint "com.apple.activity_tracing.cache-delete" from owner: com.apple.aslmanager
Feb 22 08:22:25 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.bsd.dirhelper[194]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.bsd.dirhelper
Feb 22 08:22:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[222]): Service exited with abnormal code: 255
Feb 22 08:22:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [DFRDisplayRegisterForNotification]
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [DFRDisplayRegisterForNotification] create notification port 0x7fd1bb502330
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [DFRDisplayRegisterForNotification] add runloop source 0x7fd1bb503ce0 to runloop 0x7fd1bb41e570
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [__DFRDisplayRegisterForNotification_block_invoke] AddMatchingNotification ret = 0x0
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [deviceMatch]
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [__DFRDisplayRegisterForNotification_block_invoke] AddTerminatedNotification ret = 0x0
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [deviceTerminate]
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.212): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:40 --- last message repeated 9 times ---
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.93.4294967295): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.UASharedPasteboardProgressUI): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.DwellControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imklaunchagent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:40 --- last message repeated 1 time ---
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.93.4294967295): com.apple.noticeboard.agent: EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:40 --- last message repeated 3 times ---
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:41 Users-MacBook-Air loginwindow[93]: objc[93]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /usr/lib/libFDR_osx.dylib (0x10e3faad8). One of the two will be used. Which one is undefined.
Feb 22 08:22:41 Users-MacBook-Air loginwindow[93]: objc[93]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/EmbeddedOSInstall (0x10e363de8). One of the two will be used. Which one is undefined.
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service tried to register a port for an endpoint declared in its launchd.plist(5): service = com.apple.ManagedClient, endpoint = com.apple.mcxd
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/XPCServices/com.apple.FCiCloudPrefUpdater.xpc/Contents/MacOS/com.apple.FCiCloudPrefUpdater error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple.tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager.xpc/Contents/MacOS/DataclassOwnersManager error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc/Contents/MacOS/SandboxedServiceRunner error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc/Contents/MacOS/XPCTimeStampingService error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc/Contents/MacOS/XPCKeychainSandboxCheck error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc/Contents/MacOS/IOServiceAuthorizeAgent error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc/Contents/MacOS/com.apple.SpeechRecognitionCore.brokerd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc, error = 1: Operation not permitted
Feb 22 08:22:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[260]): Service exited with abnormal code: 255
Feb 22 08:22:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:22:44 Users-MacBook-Air launchd[1]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:46 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.92): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:47 --- last message repeated 9 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.501): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:47 Users-MacBook-Air loginwindow[93]: USER_PROCESS: 93 console
Feb 22 08:22:47 Users-MacBook-Air UserEventAgent[36]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:47 --- last message repeated 1 time ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): com.apple.AirPlayUIAgent: EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.videoconference.camera): The UserName key is not supported for non-System services.
Feb 22 08:22:47 --- last message repeated 8 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.UASharedPasteboardProgressUI): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.diagnostics_agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.fullscreen): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.notificationcenter): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.appstore): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.remotedesktoppicture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.launchpad): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.downloads): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.DwellControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 --- last message repeated 4 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.gamed): The ServiceIPC key is no longer respected. Please remove it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.icdd): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 --- last message repeated 2 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imklaunchagent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.midiserver.io): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): com.apple.noticeboard.agent: EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.alerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.customalerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.extension-trampoline): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.tcc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 --- last message repeated 3 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.passd): Unknown key for string: com.apple.application-identifier
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, caller = loginwindow.93
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.protectedcloudstorage.protectedcloudkeysyncing): Invalid type for event (event/type): Interval/int64
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.protectedcloudstorage.protectedcloudkeysyncing): Invalid type for event (event/type): Priority/string
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.PubSub.Agent): The ServiceIPC key is no longer respected. Please remove it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.quicklook.ui.helper.active): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ReportCrash): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ReportCrash.Self): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.SafariCloudHistoryPushAgent): The UserName key is not supported for non-System services.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.sharingd): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.Siri.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): events/array
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): bundleid/string
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.storeinstallagent.plist, caller = loginwindow.93
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.systemuiserver.ServiceProvider): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dockextra.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.SUISMessaging): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ipodserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.systemuiserver.screencapture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.tsm.uiserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dockling.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.trustd.agent.plist, caller = loginwindow.93
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.UserEventAgent-Aqua): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.usernoted): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air logd[52]: metadata page is missing PID information for notifyd (99)
Feb 22 08:22:47 Users-MacBook-Air logd[52]: metadata page is missing main binary UUID info notifyd (99)
Feb 22 08:22:47 Users-MacBook-Air logd[52]: metadata shared cached uuid is null (using logd's shared cache info) notifyd (99)
Feb 22 08:22:47 Users-MacBook-Air CommCenter[272]: objc[272]: Class CTAsciiAddress is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffae2fa860) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10ee72b40). One of the two will be used. Which one is undefined.
Feb 22 08:22:47 Users-MacBook-Air CommCenter[272]: objc[272]: Class CTPhoneNumber is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffae2fa900) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10ee72cd0). One of the two will be used. Which one is undefined.
Feb 22 08:22:48 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 22 08:22:48 Users-MacBook-Air hidd[97]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:48 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.quicklook[298]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Feb 22 08:22:48 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:50 --- last message repeated 4 times ---
Feb 22 08:22:50 Users-MacBook-Air Finder[280]: assertion failed: 16D32: libxpc.dylib + 74307 [65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93]: 0x89
Feb 22 08:22:50 Users-MacBook-Air eospreflightagent[338]: objc[338]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /usr/lib/libFDR_osx.dylib (0x1068dfad8). One of the two will be used. Which one is undefined.
Feb 22 08:22:50 Users-MacBook-Air eospreflightagent[338]: objc[338]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/Versions/A/EmbeddedOSInstall (0x106848de8). One of the two will be used. Which one is undefined.
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:50 --- last message repeated 1 time ---
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamPriority
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:51 --- last message repeated 1 time ---
Feb 22 08:22:51 Users-MacBook-Air pbs[325]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:51 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.55): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:52 --- last message repeated 9 times ---
Feb 22 08:22:51 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:52 Users-MacBook-Air xpcproxy[354]: libcoreservices: _dirhelper_userdir: 523: bootstrap_look_up returned 268435459
Feb 22 08:22:52 Users-MacBook-Air logd[52]: _handle_cache_delete_with_urgency(0x7f94e770e7c0, 1, 0)
Feb 22 08:22:52 Users-MacBook-Air logd[52]: _volume_contains_cached_data(is /private/var/db/diagnostics/ in /) - YES
Feb 22 08:22:52 Users-MacBook-Air logd[52]: 7395064 bytes of purgeable space from log files
Feb 22 08:22:52 Users-MacBook-Air logd[52]: _purge_uuidtext only runs at urgency 0 (1)
Feb 22 08:22:52 Users-MacBook-Air logd[52]: 0 bytes of purgeable space from uuidtext files
Feb 22 08:22:52 Users-MacBook-Air findmydeviced[350]: objc[350]: Class FMDPrivateUtil is implemented in both /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice (0x7fffafeb22d0) and /usr/libexec/findmydeviced (0x10ae99c70). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.200): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:53 --- last message repeated 9 times ---
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:53 --- last message repeated 1 time ---
Feb 22 08:22:53 Users-MacBook-Air mapspushd[392]: objc[392]: Class MSPUserRoutingPreferences is implemented in both /System/Library/PrivateFrameworks/MapsSupport.framework/Versions/A/MapsSupport (0x7fffb05c1460) and /System/Library/CoreServices/mapspushd (0x1077c66d0). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air akd[395]: objc[395]: Class AKToken is implemented in both /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit (0x7fffaf356740) and /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd (0x10f77d910). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air akd[395]: objc[395]: Class AKMasterToken is implemented in both /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit (0x7fffaf356790) and /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd (0x10f77d960). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.AF039CFE-2414-4393-B41B-C458F3A37527[333]): Service exited with abnormal code: 1
Feb 22 08:22:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[398]): Service exited with abnormal code: 255
Feb 22 08:22:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:22:54 Users-MacBook-Air logd[52]: _handle_cache_delete_with_urgency(0x7f94e74245c0, 3, 0)
Feb 22 08:22:54 Users-MacBook-Air logd[52]: _volume_contains_cached_data(is /private/var/db/diagnostics/ in /) - YES
Feb 22 08:22:54 Users-MacBook-Air logd[52]: 12403928 bytes of purgeable space from log files
Feb 22 08:22:54 Users-MacBook-Air logd[52]: _purge_uuidtext only runs at urgency 0 (3)
Feb 22 08:22:54 Users-MacBook-Air logd[52]: 0 bytes of purgeable space from uuidtext files
Feb 22 08:22:54 Users-MacBook-Air DuetHeuristic-BM[86]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:55 Users-MacBook-Air MRT[380]: Agent finished.
Feb 22 08:22:55 Users-MacBook-Air MRT[380]: Finished MRT run
Feb 22 08:22:55 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:56 --- last message repeated 2 times ---
Feb 22 08:22:56 Users-MacBook-Air logd[52]: metadata page is missing PID information for coreservicesd (105)
Feb 22 08:22:56 Users-MacBook-Air logd[52]: metadata page is missing main binary UUID info coreservicesd (105)
Feb 22 08:22:56 Users-MacBook-Air logd[52]: metadata shared cached uuid is null (using logd's shared cache info) coreservicesd (105)
Feb 22 08:23:01 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[424]): Service exited with abnormal code: 255
Feb 22 08:23:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[426]): Service exited with abnormal code: 255
Feb 22 08:23:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[427]): Service exited with abnormal code: 255
Feb 22 08:23:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[429]): Service exited with abnormal code: 255
Feb 22 08:23:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[430]): Service exited with abnormal code: 255
Feb 22 08:23:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamPriority
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[437]): Service exited with abnormal code: 255
Feb 22 08:23:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[438]): Service exited with abnormal code: 255
Feb 22 08:24:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[439]): Service exited with abnormal code: 255
Feb 22 08:24:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[440]): Service exited with abnormal code: 255
Feb 22 08:24:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[441]): Service exited with abnormal code: 255
Feb 22 08:24:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[442]): Service exited with abnormal code: 255
Feb 22 08:24:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[443]): Service exited with abnormal code: 255
Feb 22 08:24:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[444]): Service exited with abnormal code: 255
Feb 22 08:25:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[445]): Service exited with abnormal code: 255
Feb 22 08:25:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[446]): Service exited with abnormal code: 255
Feb 22 08:25:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[447]): Service exited with abnormal code: 255
Feb 22 08:25:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[448]): Service exited with abnormal code: 255
Feb 22 08:25:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[449]): Service exited with abnormal code: 255
Feb 22 08:25:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[450]): Service exited with abnormal code: 255
Feb 22 08:26:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[452]): Service exited with abnormal code: 255
Feb 22 08:26:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:16 Users-MacBook-Air diagnosticd[245]: System mode client started - Console (453) - mode: 0x8
Feb 22 08:26:24 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–^H√'
Feb 22 08:26:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[456]): Service exited with abnormal code: 255
Feb 22 08:26:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:27 Users-MacBook-Air Console[453]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:26:34 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–H¢'
Feb 22 08:26:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[458]): Service exited with abnormal code: 255
Feb 22 08:26:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[459]): Service exited with abnormal code: 255
Feb 22 08:26:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:54 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–^H√'
Feb 22 08:26:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[461]): Service exited with abnormal code: 255
Feb 22 08:26:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:58 Users-MacBook-Air assistantd[356]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:26:59 Users-MacBook-Air Dock[277]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:27:04 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[462]): Service exited with abnormal code: 255
Feb 22 08:27:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:14 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[463]): Service exited with abnormal code: 255
Feb 22 08:27:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:24 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[465]): Service exited with abnormal code: 255
Feb 22 08:27:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:34 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[466]): Service exited with abnormal code: 255
Feb 22 08:27:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:44 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[467]): Service exited with abnormal code: 255
Feb 22 08:27:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:54 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–H¢'
Feb 22 08:27:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[468]): Service exited with abnormal code: 255
Feb 22 08:27:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Add a comment
1 Answer
Chosen Solution
Did you solder an SMC you bought from China? Most chips sold are blank with no programming, so it sounds like you have bought and soldered a blank chip.
The only way to replace the SMC is to remove and reball the chip from a dead board of the same model and year, or buy them preballed from eBay (again, same model and year as your one).
Try this and see what happens. Make sure to check for damaged traces to the SMC, and damaged components around the SMC.
Score 1
2 Comments:
I bought the chip from a German dealer and he is programmed. Property from there already several SMC chips ordered and all worked perfectly.
Maybe it is not on the chip, because I get the Macbook with this trick to run. Are there any other parts called SMC?
by
@toptac if the original chip was working fine by doing an SMC bypass, and the replacement chip is not working at all, either you have been given a bad chip, chip with the wrong programming, or not soldered it properly.
I would try another chip and ensure it is definitely soldered properly. These chips are pulled from dead boards and reballed, there is no way to buy these new, so there is a high chance of the chip being non-working. There are a lot of signals going to the SMC which I would recommend measuring, using the schematics
by
Add a comment
Add your answer
Guido will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 3,065
