MacBook Air 13" SMC error PFM001
Maybe someone can help me.
Sorry for my bad english, i´m from germany
My Macbook Air 2013 13 inch starts with trick: Disconnect battery, hold power and after 10 seconds simultaneously connect the Magsafe.
The hardware test spares the error PFM001 (SMC error)
A new chip I've already soldered, but nothing happens, except the fan turns full power.
With the original chip it works at least with the trick.
Many Thanks
Logfile:
Feb 22 08:22:24 Users-MacBook-Air logd[52]: Time changed, updating file headers
Feb 22 08:22:24 Users-MacBook-Air coreduetd[69]: assertion failed: 16D32: libsystemstats.dylib + 10401 [4FD7934D-2E1C-366D-8B04-725203F4785D]: 0x0
Feb 22 08:22:24 Users-MacBook-Air syslogd[35]: ASL Sender Statistics
Feb 22 08:22:25 --- last message repeated 10 times ---
Feb 22 08:22:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.emond.aslmanager" tried to hijack endpoint "com.apple.aslmanager" from owner: com.apple.aslmanager
Feb 22 08:22:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.emond.aslmanager" tried to hijack endpoint "com.apple.activity_tracing.cache-delete" from owner: com.apple.aslmanager
Feb 22 08:22:25 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.bsd.dirhelper[194]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.bsd.dirhelper
Feb 22 08:22:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[222]): Service exited with abnormal code: 255
Feb 22 08:22:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [DFRDisplayRegisterForNotification]
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [DFRDisplayRegisterForNotification] create notification port 0x7fd1bb502330
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [DFRDisplayRegisterForNotification] add runloop source 0x7fd1bb503ce0 to runloop 0x7fd1bb41e570
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [__DFRDisplayRegisterForNotification_block_invoke] AddMatchingNotification ret = 0x0
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [deviceMatch]
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [__DFRDisplayRegisterForNotification_block_invoke] AddTerminatedNotification ret = 0x0
Feb 22 08:22:40 Users-MacBook-Air WindowServer[123]: 0.002 [DFR] [deviceTerminate]
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.212): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:40 --- last message repeated 9 times ---
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.93.4294967295): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.UASharedPasteboardProgressUI): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.DwellControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imklaunchagent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:40 --- last message repeated 1 time ---
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.loginwindow.93.4294967295): com.apple.noticeboard.agent: EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:40 --- last message repeated 3 times ---
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:40 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:41 Users-MacBook-Air loginwindow[93]: objc[93]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /usr/lib/libFDR_osx.dylib (0x10e3faad8). One of the two will be used. Which one is undefined.
Feb 22 08:22:41 Users-MacBook-Air loginwindow[93]: objc[93]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/EmbeddedOSInstall (0x10e363de8). One of the two will be used. Which one is undefined.
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service tried to register a port for an endpoint declared in its launchd.plist(5): service = com.apple.ManagedClient, endpoint = com.apple.mcxd
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/XPCServices/com.apple.FCiCloudPrefUpdater.xpc/Contents/MacOS/com.apple.FCiCloudPrefUpdater error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple.tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.apple.sbd.xpc/Contents/MacOS/com.apple.sbd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager.xpc/Contents/MacOS/DataclassOwnersManager error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc/Contents/MacOS/SandboxedServiceRunner error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc/Contents/MacOS/XPCTimeStampingService error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc/Contents/MacOS/XPCKeychainSandboxCheck error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc/Contents/MacOS/IOServiceAuthorizeAgent error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Path not allowed in target domain: type = uid, path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc/Contents/MacOS/com.apple.SpeechRecognitionCore.brokerd error = 1: Operation not permitted, origin = /System/Library/Frameworks/Security.framework/Versions/A/MachServices/SecurityAgent.bundle
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCTimeStampingService.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/XPCServices/com.apple.SpeechRecognitionCore.brokerd.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/IOKit.framework/Versions/A/XPCServices/IOServiceAuthorizeAgent.xpc, error = 1: Operation not permitted
Feb 22 08:22:41 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SecurityAgent.242): Failed to bootstrap path: path = /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/XPCKeychainSandboxCheck.xpc, error = 1: Operation not permitted
Feb 22 08:22:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[260]): Service exited with abnormal code: 255
Feb 22 08:22:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:22:44 Users-MacBook-Air launchd[1]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:46 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.92): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:47 --- last message repeated 9 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.501): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:47 Users-MacBook-Air loginwindow[93]: USER_PROCESS: 93 console
Feb 22 08:22:47 Users-MacBook-Air UserEventAgent[36]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:47 --- last message repeated 1 time ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): com.apple.AirPlayUIAgent: EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.videoconference.camera): The UserName key is not supported for non-System services.
Feb 22 08:22:47 --- last message repeated 8 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.useractivityd): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.coreservices.UASharedPasteboardProgressUI): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.diagnostics_agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.fullscreen): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.notificationcenter): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.appstore): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.remotedesktoppicture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.launchpad): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dock.downloads): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.DwellControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 --- last message repeated 4 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.gamed): The ServiceIPC key is no longer respected. Please remove it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.icdd): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 --- last message repeated 2 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imklaunchagent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.midiserver.io): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): com.apple.noticeboard.agent: EnablePressuredExit is not compatible with KeepAlive=true. Ignoring EnablePressuredExit.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.alerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.customalerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.extension-trampoline): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.tcc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.notificationcenterui.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 --- last message repeated 3 times ---
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.passd): Unknown key for string: com.apple.application-identifier
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, caller = loginwindow.93
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.protectedcloudstorage.protectedcloudkeysyncing): Invalid type for event (event/type): Interval/int64
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.protectedcloudstorage.protectedcloudkeysyncing): Invalid type for event (event/type): Priority/string
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.PubSub.Agent): The ServiceIPC key is no longer respected. Please remove it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.quicklook.ui.helper.active): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ReportCrash): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ReportCrash.Self): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.SafariCloudHistoryPushAgent): The UserName key is not supported for non-System services.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.sharingd): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.Siri.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): events/array
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): bundleid/string
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.storeinstallagent.plist, caller = loginwindow.93
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.systemuiserver.ServiceProvider): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dockextra.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.SUISMessaging): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ipodserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.systemuiserver.screencapture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.tsm.uiserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.dockling.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.trustd.agent.plist, caller = loginwindow.93
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.UserEventAgent-Aqua): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.usernoted): This service is defined to be constantly running and is inherently inefficient.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 22 08:22:47 Users-MacBook-Air logd[52]: metadata page is missing PID information for notifyd (99)
Feb 22 08:22:47 Users-MacBook-Air logd[52]: metadata page is missing main binary UUID info notifyd (99)
Feb 22 08:22:47 Users-MacBook-Air logd[52]: metadata shared cached uuid is null (using logd's shared cache info) notifyd (99)
Feb 22 08:22:47 Users-MacBook-Air CommCenter[272]: objc[272]: Class CTAsciiAddress is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffae2fa860) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10ee72b40). One of the two will be used. Which one is undefined.
Feb 22 08:22:47 Users-MacBook-Air CommCenter[272]: objc[272]: Class CTPhoneNumber is implemented in both /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony (0x7fffae2fa900) and /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter (0x10ee72cd0). One of the two will be used. Which one is undefined.
Feb 22 08:22:48 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 22 08:22:48 Users-MacBook-Air hidd[97]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:48 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.quicklook[298]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Feb 22 08:22:48 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:50 --- last message repeated 4 times ---
Feb 22 08:22:50 Users-MacBook-Air Finder[280]: assertion failed: 16D32: libxpc.dylib + 74307 [65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93]: 0x89
Feb 22 08:22:50 Users-MacBook-Air eospreflightagent[338]: objc[338]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /usr/lib/libFDR_osx.dylib (0x1068dfad8). One of the two will be used. Which one is undefined.
Feb 22 08:22:50 Users-MacBook-Air eospreflightagent[338]: objc[338]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x7fffb06a36e0) and /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/Versions/A/EmbeddedOSInstall (0x106848de8). One of the two will be used. Which one is undefined.
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:50 --- last message repeated 1 time ---
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamPriority
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:50 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:51 --- last message repeated 1 time ---
Feb 22 08:22:51 Users-MacBook-Air pbs[325]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:51 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.55): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:52 --- last message repeated 9 times ---
Feb 22 08:22:51 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:52 Users-MacBook-Air xpcproxy[354]: libcoreservices: _dirhelper_userdir: 523: bootstrap_look_up returned 268435459
Feb 22 08:22:52 Users-MacBook-Air logd[52]: _handle_cache_delete_with_urgency(0x7f94e770e7c0, 1, 0)
Feb 22 08:22:52 Users-MacBook-Air logd[52]: _volume_contains_cached_data(is /private/var/db/diagnostics/ in /) - YES
Feb 22 08:22:52 Users-MacBook-Air logd[52]: 7395064 bytes of purgeable space from log files
Feb 22 08:22:52 Users-MacBook-Air logd[52]: _purge_uuidtext only runs at urgency 0 (1)
Feb 22 08:22:52 Users-MacBook-Air logd[52]: 0 bytes of purgeable space from uuidtext files
Feb 22 08:22:52 Users-MacBook-Air findmydeviced[350]: objc[350]: Class FMDPrivateUtil is implemented in both /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice (0x7fffafeb22d0) and /usr/libexec/findmydeviced (0x10ae99c70). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.user.200): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Feb 22 08:22:53 --- last message repeated 9 times ---
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:53 --- last message repeated 1 time ---
Feb 22 08:22:53 Users-MacBook-Air mapspushd[392]: objc[392]: Class MSPUserRoutingPreferences is implemented in both /System/Library/PrivateFrameworks/MapsSupport.framework/Versions/A/MapsSupport (0x7fffb05c1460) and /System/Library/CoreServices/mapspushd (0x1077c66d0). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air akd[395]: objc[395]: Class AKToken is implemented in both /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit (0x7fffaf356740) and /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd (0x10f77d910). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air akd[395]: objc[395]: Class AKMasterToken is implemented in both /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit (0x7fffaf356790) and /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd (0x10f77d960). One of the two will be used. Which one is undefined.
Feb 22 08:22:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.AF039CFE-2414-4393-B41B-C458F3A37527[333]): Service exited with abnormal code: 1
Feb 22 08:22:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[398]): Service exited with abnormal code: 255
Feb 22 08:22:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:22:54 Users-MacBook-Air logd[52]: _handle_cache_delete_with_urgency(0x7f94e74245c0, 3, 0)
Feb 22 08:22:54 Users-MacBook-Air logd[52]: _volume_contains_cached_data(is /private/var/db/diagnostics/ in /) - YES
Feb 22 08:22:54 Users-MacBook-Air logd[52]: 12403928 bytes of purgeable space from log files
Feb 22 08:22:54 Users-MacBook-Air logd[52]: _purge_uuidtext only runs at urgency 0 (3)
Feb 22 08:22:54 Users-MacBook-Air logd[52]: 0 bytes of purgeable space from uuidtext files
Feb 22 08:22:54 Users-MacBook-Air DuetHeuristic-BM[86]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:22:55 Users-MacBook-Air MRT[380]: Agent finished.
Feb 22 08:22:55 Users-MacBook-Air MRT[380]: Finished MRT run
Feb 22 08:22:55 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:22:56 --- last message repeated 2 times ---
Feb 22 08:22:56 Users-MacBook-Air logd[52]: metadata page is missing PID information for coreservicesd (105)
Feb 22 08:22:56 Users-MacBook-Air logd[52]: metadata page is missing main binary UUID info coreservicesd (105)
Feb 22 08:22:56 Users-MacBook-Air logd[52]: metadata shared cached uuid is null (using logd's shared cache info) coreservicesd (105)
Feb 22 08:23:01 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[424]): Service exited with abnormal code: 255
Feb 22 08:23:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[426]): Service exited with abnormal code: 255
Feb 22 08:23:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[427]): Service exited with abnormal code: 255
Feb 22 08:23:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[429]): Service exited with abnormal code: 255
Feb 22 08:23:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[430]): Service exited with abnormal code: 255
Feb 22 08:23:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamPriority
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imtranscoding.IMTranscoderAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:53 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Feb 22 08:23:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[437]): Service exited with abnormal code: 255
Feb 22 08:23:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[438]): Service exited with abnormal code: 255
Feb 22 08:24:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[439]): Service exited with abnormal code: 255
Feb 22 08:24:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[440]): Service exited with abnormal code: 255
Feb 22 08:24:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[441]): Service exited with abnormal code: 255
Feb 22 08:24:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[442]): Service exited with abnormal code: 255
Feb 22 08:24:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:24:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[443]): Service exited with abnormal code: 255
Feb 22 08:24:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[444]): Service exited with abnormal code: 255
Feb 22 08:25:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[445]): Service exited with abnormal code: 255
Feb 22 08:25:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[446]): Service exited with abnormal code: 255
Feb 22 08:25:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[447]): Service exited with abnormal code: 255
Feb 22 08:25:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[448]): Service exited with abnormal code: 255
Feb 22 08:25:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:25:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[449]): Service exited with abnormal code: 255
Feb 22 08:25:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[450]): Service exited with abnormal code: 255
Feb 22 08:26:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[452]): Service exited with abnormal code: 255
Feb 22 08:26:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:16 Users-MacBook-Air diagnosticd[245]: System mode client started - Console (453) - mode: 0x8
Feb 22 08:26:24 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–^H√'
Feb 22 08:26:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[456]): Service exited with abnormal code: 255
Feb 22 08:26:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:27 Users-MacBook-Air Console[453]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:26:34 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–H¢'
Feb 22 08:26:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[458]): Service exited with abnormal code: 255
Feb 22 08:26:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[459]): Service exited with abnormal code: 255
Feb 22 08:26:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:54 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–^H√'
Feb 22 08:26:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[461]): Service exited with abnormal code: 255
Feb 22 08:26:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:26:58 Users-MacBook-Air assistantd[356]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:26:59 Users-MacBook-Air Dock[277]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Feb 22 08:27:04 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[462]): Service exited with abnormal code: 255
Feb 22 08:27:04 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:14 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[463]): Service exited with abnormal code: 255
Feb 22 08:27:14 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:24 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[465]): Service exited with abnormal code: 255
Feb 22 08:27:24 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:34 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[466]): Service exited with abnormal code: 255
Feb 22 08:27:34 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:44 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named ''
Feb 22 08:27:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[467]): Service exited with abnormal code: 255
Feb 22 08:27:44 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Feb 22 08:27:54 Users-MacBook-Air diagnosticd[245]: Failed to harvest strings for binary named '–H¢'
Feb 22 08:27:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd[468]): Service exited with abnormal code: 255
Feb 22 08:27:54 Users-MacBook-Air com.apple.xpc.launchd[1] (com.apple.watchdogd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
