engine compression 1 good cyl 1 Bad cyl
I have an ezgo cart with a robin 295cc motor 1 cyl has 150lbs compression the other had 70. put oil in each cyl. and compression went up Suggestions please. Thank you
@asherboyak ,Rick , the low compression cylinder may be able to be honed and new rings(MAYBE), Usually the engine would be torn down completely and rebuilt. Some of the small engine shops have a scope/camera that they can put in the spark plug hole to see wear/damage/etc., enabling them to diagnose with out total tear down and may be able to give an estimate. Good luck.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,473
2 Comments
Thanks i plan on repairing myself
by Rick
Rick, thanks for posting back, you may be able to find a free service manual for cart or engine online using make and model# of either eng./cart. Good luck with your repair.
by L Pfaff
