Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone won't boot after screen replacement
My girlfriend smashed her iPhone 6 screen, and after a few weeks the smashed screen died. So I bought a new screen for replacement, and I followed the instructions, but now after closing with the new screen, the phone won't turn on and the pc does not recognize the phone. I forgot to test the phone before changing the screen, I think that the problem might be the logic board or the battery died. Anyone knows what could it be?
Add a comment
1 Answer
Chosen Solution
clickpatrick , Try a reset, press and hold the home button. While holding the home button, press and hold the sleep/wake button. Continue holding both buttons for about 10 seconds, until the Apple logo appears.
Indeed if the battery is dead the device is not going to power on. Try charging the battery for a few hours and try, still no go try another compatible charger/cable and charge a few hours, if powers up defective charger. If it does not power up, take the device apart and check to see if battery/charge port connections are all good, check all connection and components on the board for loose/damaged and reseat connections to have good contact. Check to see if battery has a charge with a DVOM should see 3.7 volts more or less (charge no good , probable faulty battery). If battery OK reassemble and try the device. No go, could b bad display or logic MB(mother board). Disassembly and troubleshooting guide links below. Good luck.
iPhone 6 Teardown
iPhone 6 Troubleshooting
Score 3
Add a comment
Add your answer
clickpatrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 113
