Acer entered the world of laptop computers in 1997 when it purchased Texas Instruments' mobile PC division.
Resolve Slow system issues
My Acer is 4 years old, although it works fine but has become slow over the period of time. Did a OS reinstall as well and no heavy software. How can I improve the speed ? Please suggest.
Thanks
Sandeep G
OptimizeIndia
Add a comment
Most Helpful Answer
The things that make a computer slow are:
1.Not enough free space on hard drive
2. Excessive fragmenting on hard drive
3. Virtual memory setting wrong
4. Application resources not released, solve by rebooting
You can check the free space in My Computer, right click on the hard drive and select properties. It will show a graph to indicate how much of the disk drive is used and how much free space. In the tools section of the drive properties are the defrag tool.
Virtual memory is found in the (Windows 10) System-advanced system settings. Checked the Advanced tab and click on settings, click on advanced and you will see the virtual memory setting. Click on virtual memory settings to see if it is set to automatically adjust or if it is set manually, if it is set manually then you can increase the virtual memory. Virtual memory is a place where the OS can store and load data, it uses part of the hard drive as the virtual memory.
Other things to check: Updates, drivers and check for malware.
Score 2
Add a comment
Optimize India , Your starting with a fresh OS install will help. If you can open up your laptop and give it a good cleaning, blow all the dust/lint etc. out of fans, from board,etc. lots of Videos on line to show how. You do not state your model # or specs. You can google search your make, model # and see what maxim ram you can run, then upgrade to larger ram if able, to help speed things along. See links below for more recommendations. Good luck.
http://lifehacker.com/5883376/what-hardw...
https://www.speedupacer.com/
https://www.howtogeek.com/228570/10-quic...
Score 1
Add a comment
Add your answer
Optimize India will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
