phelante it is important to know if the lights blink simultaneously or alternatively.
If you think it is a fan then the very first thing you will have to do, is to unplug your set and disassemble it as close to the fans as possible. Your unit has multiple fans, i.e. Ballast cooling fa, lamp fan and optical block cooling fan.
3.1.31 OPTICAL BLOCK COOLING FAN
• Take out the BODY COVER.
• Take out the BODY BRACKET.
• Take out the MAIN UNIT.
(1) Remove 3 screws [ J ].
(2) Take out the SIROCCO TOP CASE.
(3) Remove 3 screws [ K ].
(4) Take out the OPTICAL BLOCK COOLING FAN.
3.1.32 LAMP COOLING FAN
(1) Remove 2 screws [ L ].
(2) Take out the LAMP FAN BRACKET ASSY.
(3) Remove 4 screws [ M ].
(4) Take out the LAMP COOLING FAN.
3.1.33 LAMP BALLAST UNIT COOLING FAN
(1) Remove 3 screws [ N ].
(2) Remove 4 screws [ O ].
(3) Take out the COOLING FAN (LAMP BALLAST UNIT).
So in order to properly diagnose what is going on with your set, you will stat having to inspect a few pieces. Use this manual JVC SM to assist you further. Let us know what you found.
