Polaroid Sun 600 LMS instant camera. Released 1983.
15 Questions View all
The red light seems to be stuck & doesn't seem to be properly working
I'm aware that I have to half-press on the red button in order to change the flash for my Polaroid.. But the red light will not turn off and change to green, and I have been waiting for several minutes.. What's wrong? It just randomly stopped working and I cannot take another photo until the light turns back to green.
Add a comment
1 Answer
Chosen Solution
natjarmay, Both the electronic flash and the camera are powered by the high-energy battery built into
every film pack. Clean the film pack contacts in the camera with a Qtip dampened with 90% Isopropyl alcohol and install new fresh good quality film pack and try the camera.
If this does not solve the problem there could be a problem in the Flash circuitry.
file:///C:/Users/Home/Downloads/600-manual.pdf
Score 2
2 Comments:
How would you recommend properly cleaning the film pack contacts?
by
natjarmay , the link below will show how to open th film pack door, with a flashlight you can look inside the compartment and see the copper contacts which should be reachable with long Qtip dampened with 90% Isopropyl alcohol, gently clean the contacts to remove any dust/corrosion/etc., You could also use a can of compressed air to blow out any dust/debri that you see.
Polaroid Sun 600 LMS Film Pack Replacement
by
Add a comment
Add your answer
natjarmay will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 65
All Time: 9,849
