I break chip while opening
I Break The Chip where the green line cut soo can i Start my iphone or this gone some sort ciruit ?
That is the antenna tuner IC. Depending on the damage, it may not stop your phone from booting up but it will certainly affect your ability to connect to WiFi or Bluetooth.
Please post a picture so we can see the damage. These IC's are available on Aliexpress.
Hi bro , sorry to tell you you'll have to buy a new circuit board . Because the battery will not be able to power up the phone , wifi and Bluetooth will not work moreover you'll not be able to switch between network ie it will on have 2g coverage as u have broken the network chip . By the way why u just open that fuc**** phone.Jokes apart flash and front camera will be unable to start properly . It will also affect the auto brightness function . According to me it's of no use . Only warranty will help u if any problem reply me
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 76
3 Comments
So you broke that section of the chip off the board? Or if the entire board broken off?
by Gigabit87898
@sonkesriya instead of drawing lines on an image just post some pictures of of your damaged board with your question. That way we can see what you see and can try to help you without having to guess. Use this guide to post images Adding images to an existing question
by oldturkey03
Only that Small green line .. where the chip se get broken
by Somesh Sonkesriya
