window regulator new replacement
Having problems replacing drivers door window regulator,cant seem to line up the top bolts to the holes no room or play,do I have to remove the window which is in the up position wedged,if yes how please.
Add a comment
1 Answer
Chosen Solution
davies , You should not have to remove the window, It would be good if you could get a second set of hands. You may have to unwedge/lower the window or change its position to get it to line up for assembling on the regulator. The video is not of your car but may aid in showing the assembly of regulator back onto the window. Good luck.
https://www.youtube.com/watch?v=GLFvtyV5...
Score 2
1 Comment:
Thank you for your answer,I have sorted it now,great!
by
Add a comment
Add your answer
davies will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 153
