Is there a trick to attaching replacement battery to pins on board?
I removed the old battery ribbon and little l shaped pins came with it. There are little pins on the board but the new ribbon will not attach. Is this a problem?
1 Comment
Ok thanks. I guess it's blown.
Here are photos.
[image|1021081]
[image|1021084]
by
Add a comment
1 Answer
Chosen Solution
Sounds like you have pulled the grey plastic battery connector off of the board, which has just left the pins soldered on the board (you are supposed to pull the battery ribbon out of the connector, not lift it upwards).
If this is the case, the only way to resolve this is to remove the battery connector from a donor board and solder a new one on, which I would not recommend undertaking unless you have the tools and experience.
Upload a picture so we can be sure, but it sounds like you will have to send it to a repair centre who carries out logic board repairs.
Score 4
Add a comment
Add your answer
Deirdre Rogan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
