Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 won't charge after battery is fully discharged
The iPhone 5 refuses to charge once the battery is completely discharged. I have changed the battery and the charging port and problem is still there.
When I put a charged battery in, the phone shows that it's charging when plugged in. But again, once it empties to zero, charging it does nothing.
Someone said i should be doing a hard reset. Anyone have any definitive answer please?
Score 1
Add a comment
1 Answer
Chosen Solution
No charging on flat battery or turned off means bad U2 Tristar charging chip.
Get the U2 Tristar Charging IC chip replaced.
It's a component on the logic board that goes bad when the user uses a copy lightning cable / non-certified MFi lightning cable or a car charger.
You will need to find someone that does microsoldering for charging IC on iPhones.
Score 5
1 Comment:
Thanks. I suspected it was IC related. But it's been very strange. I put a new battery in and after a couple of minutes it started charging. I also updated to iOS 10.2 and during download and install, the phone turned off a couple of times but it finally installed.
I've discharged and recharges a couple of times and seems to be a lot more stable now. See how it goes and thanks for the advice
by
Add a comment
Add your answer
Amir A will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 246
