ODD & CPU above 3000 RPM iMac 27 mid 2011 Fan full Speed
Hi Please Dan I need your help what I should do !
I did contact my Imac 27 mid 2011 Via TV , but the Fan with Full speed loudly show up .
I coudn't use the LCD as you see the problem on the photo , molex connector
i'm fine to use TV as monitor but the problem of full speed fan is really loudly
also is it ok to run my Imac with this issue until I find solution .
Here some photo :
Logicboard molex problem !
3 Comments:
did you change the hard drive?
by
No I didn't . I have plan for that once I receive OWC (In-line Digital Thermal Sensor)
by
Add a comment
1 Answer
Check all the temp sensors, like the HDD sensor. Iff they are not connected or faulty, your iMac will run the fans at maximum.
2 Comments:
my is Imac 27 mid 2011 EMC No:2429
the HDD came without sensor only power & data cables
by
Still, the 'save mode' in an iMac is that iff there is a faulty temp sensor (any sensor, not just HDD sensor), than the fans go full speed.
So iff there is a sensor missing, not connected etc, same will happen !
by
Add a comment
Add your answer
Mr. MAC will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 718
