The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Questions View all
Ordered an Unlocked, Int'l. Galaxy Note 4 N910C, received an N910T2
I use NET 10 as my provider in AT&T & Verizon coverage areas. The Note 4 N910C was described as compatible with AT&T 4G LTE coverage. When I received the N910T2 phone, however, it was an unlocked T-Mobile phone, and the website description was that it was NOT a fully compatible phone (not sure if that meant with AT&T, or even with T-Mobile), but at any rate, we have NO coverage for T-Mobile here. I've contacted Samsung, they say if it's an unlocked phone, it should be compatible with AT&T.
So should I just treat this phone as if it's AT&T compatible, and use the APN settings for an AT&T compatible phone?
And get the Marshmallow updates directly from Samsung? Because I obviously won't be getting any updates from AT&T, NET 10, or T-Mobile, right?
1 Comment
How can I update my samsung galaxy note 4 n910t2 from kitkat to marshmallows?
by
Add a comment
Chosen Solution
I hate bait and switch sellers. Thankfully, no harm in this one.
The 910C has 64-bit Exynos processors while the 910T has a 32-bit Qualcomm CPU. Argumentatively, both have similar performance.
The 910C has slightly different LTE band support (geared toward EU LTE), but both 910C and 910T have support for LTE bands 2,4,5,17, which is what AT&T uses, so you are ok here.
Regarding updates, however, the 910T will receive updates from T-Mobile. They actually have been really good about this. They have not only provided the Marshmallow update, they have provided security updates up to January 2017 so far.
Score 3
4 Comments:
I have the same problem: received a 910t2 instead of the 910C that i need here in the Caribbean,
I would really like to know how to update it from Kit Kat. Can anyone give me specific instructions/links??
by
Is the 910T the same as the 910T2??
by
T-Mobile provides un-restricted free updates.
Simply go to Settings --> About Phone --> Software updates.
It should update to 6.0.1.
by
Hey SW, thank you. However, it goes through the process of updating but remains 4.4.4 . Nothing changes.
by
Add a comment
I having the same problem with my note 4 n910t2. ... how can i update from kitkat to marshmallows?
Add a comment
Add your answer
Sigrid C will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 333
