Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20001 Questions View all
System hang, refuses to boot for a while & has pixelated error screen
Dear Ifixit,
I recently started using my brother's Mac book pro. He let me have it after it stopped booting randomly. For a while it worked perfectly, no issues with booting, resuming from sleep or battery/power related problems.
Today for the first time it started crashing again. I manged to get a shot of the error screen with my phone. There are black patches all over the screen with an error message at the top.
I'm led to believe that this is a motherboard issue and hence will need a replacement. I'm also told that the Apple techs couldn't make out the problem. I hope that this problem has been seen before and that it has an, affordable, solution.
A photograph of said error screen:
http://imgur.com/ZeJgTNl
Thank you.
Add a comment
1 Answer
Chosen Solution
I've seen that in relation to Gpu failures. If that's the case, if you try using a graphic intensive application, like unigine engine, the mac will shut down within a couple of minutes or so..you can give it a try for confirmation.
Score 3
1 Comment:
Dear Arbaman,
Thank you for the response, I will try it out. The first time I had it crash was when I was browsing the net while copying 2.5 GB of files. The weird thing is it works fine after a few attempts to boot.
Since the last crash I have used Adobe Photoshop, Premiere Pro and Indesign CC without any problem. I also tried Capture One 10 and it worked fine, although a bit slow. I should note that I didn't do any heavy duty editing or grading.
Regards
by
Add a comment
Add your answer
ARjun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
