Repair guides and support for Nextbook tablets.
390 Questions View all
Can it be hooked to a hard drive
I want to hook a external hard drive to the next book will it let me do this
2 Comments
Best way to find out is to just try it. Connect a USB drive, power up and see if it recognizes it.
by
Has anyone replaced the internal 32GB with more storage,or is it hardwired?
by
Add a comment
Most Helpful Answer
Yes...WD Passport 1 TB external hard drive...for windows
Score 1
Add a comment
James --
There are a couple of issues here: connectivity & power.
The Nextbook needs to provide enough power for whatever device you connect. Simplest test for this is to use a USB flash drive since they require little power. For a larger device, be sure the Nextbook is plugged in charging mode to provide the most power.
Next: What is the Operating System of your Nextbook?
Good luck,
Russ
Score 1
Add a comment
Add your answer
James dulworth will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,640
