27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Questions View all
Brightness can be set only on low setting
Hello community,
I have a Thunderbolt Display which was used with my Macbook Pro (Windows 8.1 via Boot Camp). 2 days ago it made a clicking sound and the picture went dark on the Windows OS. After that I took the Monitor home and tested it with my Macbook Pro at home (OS Sierra). I can set the brightness in the Apple OS but only from Dark - 1 -2 Points (using ctrl + f2), when I go on the next one (Number 3) it doesn´t get brighter and the picture starts to flicker. All the next brightness Settings do not change the flickering or get brighter.
Installed the Firmware 1.2 - didn´t do any change.
Maybe someone had a similar issue...
Thanks in advance!
Nejc
2 Comments
I lifted the LCD Pannel, checked all the Connections (couldn´t see any problems). Left it alone for 3 days. After that it started working as usual again....
by
Did the issue ever come back?
by
Add a comment
1 Answer
Chosen Solution
It sounds like something went screwy with the power regulator that feeds the backlight.
3 Comments:
Well after I unplugged the Monitor it showed the same symptoms... Can I somehow repair the power regulator for the backlight? Or do I have to change it?
by
Have a similar issue. If display brightness is set to above 70% after several minutes of use the screen goes black. Works totally fine if the brightness is below 70% (approximately). Replaced the power supply and tried a separate TB cable neither helped resolve the issue.
by
Hi Guys, having similar Issue. TBD flashing sometimes and later blackouts. When i lower the brightness it seems to work ok. Did you find out anything about the hardware or software driven reason of this problem? cheers!
by
Add a comment
Add your answer
Nejc Sitar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 590
