Sportster keeps cutting off.
It ran good yesterday, no issues. Today while riding, it cut off completely and after setting for a few minutes, it would start back up, run a little, then cut off again. I had to repeat this process until I was able to get back home....a lot of coasting! New battery, fresh gas, plugs about 2 yrs. old. Any help is appreciated.
Score 1
2 Comments
I just bought a 2000 sportster it had been sitting in the garage for a few months . it turns on great but shuts off after about 10 minutes ibe tried riding it and it shuts off about a quarter mile.i have to wait for it to cool off before it starts
by
I have a 2003 Sportster 1200 and it just shuts down after about 10km. If I let it sit for ten or 15 minutes it’ll start again but I can only get 1/2 km up the road and it’ll shut down again. Could it be a coil. Any help would be appreciated. Cheers Julie.
by
Add a comment
1 Answer
Chosen Solution
@hanoverdigger , Robert Brown ,Throw some new plugs in, check petcock not on reserve, fuel cap not venting(remove or loosen cap and try), clogged fuel filter/in tank strainer(remove and check/replace), faulty carb.(dirty/sticking float,accelerator pump bad, Rebuild and set carb. up), Vacuum leaks(with engine running-use starter fluid to spray around carb. flanges/vacuum lines), check plug wires(cracked/burnt/loose), bad ignition modules/coil, intermittent short in wiring/bad grounds, etc,etc.. Find 2 links below where you can down load the service manual from for free to help diagnose and repair your Sportster. If not comfortable diagnosing and working on your bike, have a good technician have a look, diagnose and estimate repair. Good luck.
http://www.carlsalter.com/harley-service...
http://motoservicemanual.com/harley-davi...
Score 4
2 Comments:
Thanks for the reply. I talked with my mechanic and he thinks it may be a carb. problem. I'm sure he can take care of it.
by
Robert, your welcome, Keep the Shiny side up. Good luck.
by
Add a comment
Add your answer
Robert Brown will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 2,278
