Why won't my iPad 2 recharge
I have had the iPad2 plugged in and charging for the past 6 hours and the battery symbol is still showing 0% battery charge.
Hi Sharon, here are a few things you should check:
You can check out the iFixit guide on replacing the battery. There are a lot of potential traps when removing the digitizer, handling the LCD and replacing the battery but it is certainly doable if you are used to fixing stuff.
You should download CoconutBattery (for Mac) or 3uTools for Windows. They have the ability to test your battery. If you have less than 80% of the original design capacity, you should consider changing the battery. If you have less than 60%, then you HAVE to change the battery.
On my ipad2 it started not charging most likely for
A bump it received that damaged the volume control. However I have found that letting the iPad battery completely drain does something. I plug it in and the next day it is 100%.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 134
