Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
iSight cable broken. Solder and wiring info needed.
My iSight cable snapped right in half. The very thin red and green wires are lined up so I think I know the correct way to re-wire it but does anyone have tips on how to solder these super thin wires. I can barly strip them without breaking them.any help would be awesome as a new iSight cable is $50-$80 dollars which I dont have.Thanks.
Score 1
Add a comment
Chosen Solution
Well, I would use a small soldering iron with a small tip and a fixture to hold the cable in place as well as a magnifying light. it can be done just have to be patient and prepared. The pinout as well as more information for the insight cable is here http://www.insanelymac.com/forum/lofiver... and here http://forums.applecentral.com/ubbthread... The information for the pinout that I got is
Pin 1 is the left most (has an chevron pointing to it). LVDS/iSight cable wire color in parenthesis.
Pin 1 (dark blue): connects to a pad on a 6 pin footprint for a chip that is not installed
Pin 2 (dark blue): connects to a pad on a 6 pin footprint for a chip that is not installed
Pin 3 (light blue, white conductor): USB D+
Pin 4 (light blue, purple conductor): USB D-
Pin 5/6 (orange): USB VCC (+5VDC)
Pin 7/8 (orange): USB GND
Score 1
2 Comments:
Thanks! Very informative info. The only problem is my iiSight cable has 2 red wires and the rest are green. So it's a little difficult to match up which green wires connect to each other.
by
anthony g, may be this pic can help you a little better not the best but it shows the connector with the colors of the cable. http://htmlimg4.scribdassets.com/9bzpb6m...
by
Add a comment
can you re-upload the pic to see the pinout of the connector on the motherboard?
1 Comment:
@oldturkey03 notice given
by
Add a comment
Add your answer
Dirk Funk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 4,369
