Guides and support for various television (TV) brands and styles.
9064 Questions View all
No Programme error on blank screen LG tv model 50PG20D
Hi, just moved into a new unit - antennae connected to wall socket, getting error 'No Programme', have turned on/off, tried auto-tuning, tried manual tuning & tried 'factory reset' but has not worked, same error.
LG tv model 50PG20D
Any other options to try? should i just go get a new tv?
Cheers
Annie
Add a comment
1 Answer
Chosen Solution
@anniesikovitch try a different input source, not the current antenna setup you are using. Use a DVD or similar and see if you can get something to show up. "'No Programme'" sounds like it just does not have a signal. Just in case you are unsure how to select different inputs etc. use the user manual User Manual LG 50PG20D
Score 3
Add a comment
Add your answer
annie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 129
