Can I use LG J10HD-sa with out main player?
Hi,
I have LG J10HD-sa
the main console is broken.
I still have:
Is it possible to run it from aux cable, with out main console?
Manual:
https://www.manualslib.com/manual/242904...
https://www.encompassparts.com/shop/mode...
Update (02/07/2017)
Is there any parts to spare?
3 Comments
Hi jayeff .
Okej.....i hoped that i could make only aux work.
by
Hi, can you run the speakers without the console? I have the same problem, and I lost the cables. If you have the cables, could you do me a favor? Would you know the connection between the serial port pins and the two 2-pin GX connectors?
by
estoy buscando los cables de conexion de lg j10hd-sa pueden darme respuesta de que si los puedo conseguir
Google translate:
I am looking for the connection cables of lg j10hd-sa can you give me an answer that if I can get them
by
Add a comment
1 Answer
Chosen Solution
Hi,
What is wrong with the main console?
Initially I would say that you cannot do what you ask.
A quick read of the manual indicates to get the aux input to work you need to select Mobile using the remote control (presumably to the console), which then would switch the input connection to the auxiliary input and away from whatever input it was on..
Here is a link to the relevant section in the manual.
Score 2
Add a comment
Add your answer
Robin Sandell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 29
All Time: 2,306
