The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Questions View all
Won't connect to Xbox one unless using play and charge cable
Won't connect to Xbox one unless using play and charge cable When I don't use the play and charge kit and try turn it on it just does 2 slow flashes and turns off
2 Comments
Have you tried new batteries?
by
Yes I've tried different ones
by
Add a comment
1 Answer
Most Helpful Answer
Hey mate, give these a try and see if they fix the issue. If not, cooment back and I'll find another solution for you https://support.xbox.com/en-AU/xbox-one/...
Score 1
Add a comment
Add your answer
Archie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 11
All Time: 206
