Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
changing the chasis cause "searching" no Baseband BUT yes IMEI
All the stuff I found in internet about no Baseband firmware is joined with no IMEI number
I have checked some cables inside but still thinking that maybe the flex interconnection between upper and lower side of logic board could be the cause
I've changed the dock and 3G antenna but without solution
I think that restore will cause a brick but OTA is not able to achieve because of the error during checking system in the iPhone
Could be solved UPDATING from iTunes? Afraid of not to be able to activate
Important to note that IMEI is still present but not network, searching with and without SIM inside
1 Comment
Is there a modem firmware number in the settings??? Did you bend the board whilst you did the swap???
by
Add a comment
1 Answer
Chosen Solution
You need to find a way to get the Lightning dock to connect to the frame to ground. I have a ...hold up... Scratch Brush That or you have lightning dock problems
Scratch Brush Image
Product
Scratch Brush
$3.99
Score 3
Add a comment
Add your answer
Alfonso will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 170
