Mac Pro (2013) CPU & Riser card bus bar screws torque value
The Mac Pro (2013) CPU riser card bus bar screws need to be tightened to a torque value. Does anyone know what it is?
Are you referring to the 4x bus bars that attach and ground the CPU to the PSU? if so, it is the following:
Bus Bar to PSU Screws
Use the torque driver with the T8 security bit to install the four (4) T8 bus bar screws (923-0712) to 7.5 inch pounds (in.-lbs.) or 0.85 Newton metres (Nm).
Bus Bar to CPU Riser Screws
Using torque driver with T8 security bit, install two T8 bus bar screws (923-0716). Tighten bus bar screws to torque value of 10.5 inch pounds (in.-lbs.) or 1.2 Newton metres (Nm).
If you are referring to the CPU heatsink and locking bar, its as follows:
Using torque driver with a regular T10 bit, install four T10 screws (923-0707) in sequence shown until all screws are tightened to 10.5 inch pounds (in.-lbs.) or 1.2 Newton metres (Nm).
I hope this helps.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 597
