The LG G Pad 8.3 is a tablet created by LG Electronics Inc. that weighs 11 ounces, has 16 GB of storage, and has a 8.3 inch screen.
20 Questions View all
Got new battery for lg vk810 let it go dead
I got a new battery for lg 8.3 vk810 accidentally I let it completely die now I can't get it to charge or turn on I tried the 20second thing but it still won't do. anything. Also my screen is very dim?
5 Comments
lisasaunders528 "still won't do. anything. Also my screen is very dim?" so it does come on but has a very dim screen? Clarify this for us. A dead battery would not give you anything.
by
I replaced the battery and was working fine for a couple of days but then accidentally. Let it die now I can get it to charge or turn on
by
Sounds like you are having an issue with either your charging cable, your charger, or the charging port. Have you tried a different charger/cable?
by
Yes I've tried different cable and charger box it will sometimes show me the LG screen but can't get it to go past that I just ordered a new charger Port with flex cable so I hope it's the problem.
by
Also every once in a while I get a faded ring around the outside of the screen does that have anything to do with it or is that a hole new problem itself?
by
Add a comment
Chosen Solution
Got the new flex cable in and its working great thank you for your help
Score 1
Add a comment
Most Helpful Answer
Try disconnecting the battery for a few minutes then replace battery and before turning it on plug it in and let it charge . Leave it plugged in for a day. see if this helps
just in case you need a guide
LG G Pad 8.3 Battery Replacement
Score 2
3 Comments:
It's a new battery I just replaced it. And I let it charge over night
by
disconnect it then reconnect it before recharging . Connection may not have seated correctly . Check connection for dirt or lint
by
Installed. New flex cable and port and is working great now thank you
by
Add a comment
Add your answer
lisasaunders528 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,227
