Repair guides and disassembly information for Apple's Macintosh personal computers.
42855 Questions View all
Question Closed
BLANK screen! Backlight OK, external OK. Sometimes(randomly) works?
Hi all, I've been browsing these forums a bit, any help/tips are appreciated in advance.
Symptoms:
- Blank/BLACK Screen (normally doesn't display images on laptop screen)
- Backlight works (lights up, but all "black."
*Display changes in brightness by using the dimmer/brighter keys (goes from blacker black, to "brighter" black/greyish color.
- Displays images on external monitor without problem.
- SOMETIMES, the laptop screen displays PERFECTLY (all of the sudden, as if resurrected. But then, like a ghost, it is gone, as if I was just imagining it (If I shut it?/adjust screen angle?)
Possible cause
It fell out of my bag when I slipped on some ice running late to work. (Apple care says "sorry, we can fix that for $600-700)
Could it be that there is a connection that is simply loose/damaged? Because it SOMETIMES works. perfectly.
Some ideas i've noticed on this site (but I don't really know how to interpret/evaluate them further, as I am not a computer whiz)
- Logic board connection
- display data cable?
- LCD or display data cable OR inverter?
- Cable that connects LCD to motherBoard?
- Inverter Cable?
- LCD panel?
Any advice on how to proceed/what tools I would need? I'm a college kid, struggling without it! Thanks in advance!)
(My computer) =
MacBook, 13"
(aluminum casing)
~2008? (one of the first ones just introduced)
Katrina
Add a comment
1 Answer
Check cable going to the lcd. If it sometimes works and the back-light works and the external works... cable. LCDs don't go bad without a lot of work. cracks. excessive heat (in the sun or fire heater etc) will destroy a lcd but it will not come on sometimes. It will vent off and never work again. Same with the cracks.
Check the cable.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,635
