Why I can see the picture on the screen?
I can hear everything and I got power but I can't see anything, what could be the problem?
@carlangas74 start by running the self diagnostics to see if it gives you a code:
SELF DIAGNOSTICS
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the MSD (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the LSD (ones digit) of the Error Code.
So count the red blinks and then the yellow blinks let us know what number of blinks you see.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds then restore power.
It is possible that you have an inverter issues, a lamp issues as well as anything in between.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 43
