Why the forklift is Runing idle rough in the morning
I have hyundai 160D-7 with cummins QSB5.9-C thats runs idle rough in the morning , sometimes stops. After about one hour the forklift works fine .
The next day, the same thing happens. Rarely, it works fine for the first time.
we changed all the injector nozzles and the lift pump ,we clean the tank . we changed all the filters.
the engine still runs idle rough in the morning .
I would like to resolve this issue
5 Comments
Do live in cold weather? What type of fuel is your forklift? Gasoline, diesel, propane?
by George A.
7 degree celsius in the morning 20 degree in afternoon . The forklift uses diesel
by Société Zitouna
That isn't too cold... I thought that it may be because of cold weather, and it may need to warm up before use like a car.
by George A.
When i turn on the first time it takes time to warm up . In the morning i need more time but once it s ok the forklift works fine even i turn off and after 3 hours i turn on it works perfectly
by Société Zitouna
I would speak with an engineer. Problems like these are often encountered in cars, so I am sure that this is an easy fix. Any problem related to the mechanical part is pretty terrible since you cannot use the machine at all until you are able to fix it. Or you can try speaking with someone from https://anguslifttrucks.co.uk/forklift-h... and I am sure that they are more than happy to help you out. Common problems can be easily fixed if you are working with someone that is capable of doing that
by MaryMiller
