Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
USB Not working after screen replacement
Hi all!
I replaced the screen on my iPhone 6 plus and just when starting it I noticed the boot was extremely slow, like 10 minutes just to have the phone running again, then now in the home screen I see the touch id is not working (the new screen has it) and also the phone isn't charging and If I put it on DFU mode and connect it to PC or MAC them will not detect the phone
The unique way to have the phone charging is to leave it discharge to dead (0%) and plug it, it will charge until 2%, will automatically start and that's it, it will not charge any more
Any idea what can i do?
Add a comment
1 Answer
Chosen Solution
I assume the phone worked properly before you did the screen replacement.
Did you follow this guide? Of particular importance is Step 12. Notice how the screws are of different lengths? There is only 0.3mm difference between the short ones and the next closest.
If you mixed up those screws, you may have damaged the logic board. This is commonly called Long-Screw Damage.
This is what I fear in your case.
Of course, depending on if you used heat or not on the device to open (not necessary), there may be other logic board problems such as U2/Tristar (it communicates with the Lightning Port and "talks" with certified chargers).
So go back through the steps of the guide and let us know if everything was done properly. You will probably need to find an experienced micro-soldering repair shop to fix this.
Score 1
Add a comment
Add your answer
Jose Restrepo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 215
