Clothes dryer repair and support guides.
870 Questions View all
Noisy when after running awhile, and overheating.
When my frigidaire gler64as3 dryer runs after about5-10 minutes give or take, it starts making a funny noise ,then gets really hot. kind of smells like something is burning. its get the things inside really hot.
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Heating Element
The heating element warms the air before the air enters the dryer drum. If the element is partially shorted out, it may produce heat continuously, even if the dryer has reached the proper temperature. When this happens, the dryer gets too hot. To determine if the heating element is at fault, use a multimeter to test each terminal for continuity to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Cause 2
Heating Element Assembly
The heating element warms air as it passes over the element. If the element is partially shorted out, it may produce heat continuously, even if the dryer has reached the proper temperature. When this happens, the dryer gets too hot. To determine if the heating element is at fault, first use a multimeter to test the heating element for continuity. If the heating element does not have continuity, replace it. Next, test for continuity from each terminal to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Cause 3
Air Flow Problem
If the vent is clogged or partially clogged, it will restrict the airflow through the dryer, substantially increasing the drying time. To ensure proper dryer performance, you should clean your dryer’s venting system at least once per year.
Score 3
Add a comment
Add your answer
kenneth will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 60
All Time: 5,623
