Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
334 Questions View all
Accuracy in power adapter to harddrive 0.05A difference
I opened an external harddrive.
The drive inside had
5VDC - 0.7A
12VDC - 0.5A
The drive I want to replace it with has:
5VDC - 0.60A
12VDC - 0.45A
Can I replace the drive without any problem or will it break down due to the extra Amp pushed into it?
Add a comment
1 Answer
Most Helpful Answer
@junounchanged you are fine with that drive. The difference that small in amperage is negligible.
Score 1
1 Comment:
Hi, To add to OT03's answer, as long as the voltage is the same the device will only draw the current that it needs. The only way to get more current to flow is to increase the voltage supply. (Ohm's Law)
by
Add a comment
Add your answer
hlundstedt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 52
