2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Bezel cracked, display jumpy
The bezel on my wife's 2007 15-inch Core2Duo MacBook Pro has a crack just above the base on the right side. The display jumps a little. It doesn't flicker. I need some informed speculation before I try to replace anything. The jumpy display suggests some electronics or wiring is bad, but not necessarily that the display itself is bad. If I tackle this, what parts would probably see me through? Bezel. Wiring? Display?
Add a comment
1 Answer
Chosen Solution
That models display frame usually breaks on the left side about an inch up from the bottom left hand corner as you are looking at the machine. @mactech has repaired a few of these and is better qualified than I to give you a comprehensive answer.
Score 3
Add a comment
Add your answer
bobball will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 114
