What 2 wires are for the battery to charge it
the charger port broke on the inside and i need to know what 2 wires on the battery i need to clip to direct wire a charger cable to so i can charge the tablet
well, I am not sure about the charge port pinout. But if you are going right to the battery it would be the black for negative and red for positive. I often boost batteries with an old charger that I cut and strip the positive and negative leads then hold that to the battery. If you can solder you should be able to make jumpers on the board to the charge port.
hope this helps.
Which red and black wires there is 2 red wires, 2 black wires and a blue wire in the middle
Which 2 wires do I hook up to in my Alcatel tablet to charge it
Or don’t be a cheap ass and have the charging port replaced by a experience micro soldering technician. It’s better than soldering to the positive and negative leads as you risk shorting out the logic board.
Some people do not have the money to pay someone to replace the charging port. Maybe he spent that on food or diapers or gas. Maybe he still wants his tablet to work as well. Calling someone a "cheap ass" is extremely rude. Calling him that and then not even offering a solution to his problem is even worse. You literally had to go out of your way to post that comment. Kind of like I am now. No one likes a bully. Did it make you feel better? Did it make you feel like a man? I imagine you do that kind of thing quite often to make up for whichever shortcomings that you have to deal with in life. I should not have to reiterate basic human courtesy to a grown ass man. I have something else to correct you on as well. What you said should be phrased "have the charging port replaced by AN experienceD micro soldering technician". That is the correct way. The incorrect way would be "have the charging port replaced by A experiencE micro soldering technician", which is what you said. You're welcome for the lesson.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 37
All Time: 4,207
