This laptop includes a 15.6 inch screen display, 500GB hard drive, and an Intel Core i3 processor. Released in February 2012, it is identified by model number NP300E5A-A02UB.
22 Questions View all
Can this model be upgraded to ssd?
Hi I have the Samsung NP3--e5a-S07AU Notebook and was wondering if this can be upgraded to SSD
Thanks
Sean
1 Comment
My model is Samsung NP300E5A_S07AU I believe it is possible
by
Add a comment
Chosen Solution
seanwp2 if your machine is a Samsung NP300e5a then you can simply remove the hard drive and replace it with a SSD as @danekjohnson has said it will greatly increase you boot speed and you will defiantly notice better battery life. If however the -- in the model number you showed above refer to some other model then I cannot say with certainty that this will work. Hope this helps
Score 3
Add a comment
Most Helpful Answer
Yes you can place a SSD in your computer. This computer has a 2.5" spinning disk drive and you will see massive performance and battery gains from this kind of swap. You will need to find a sata 2.5" SSD. I have lots of luck with the samsung evo 850 drives.
Regards,
Dane K. Johnson
Score 3
2 Comments:
Cheers Samsung said that I couldn't lol :D
by
I assure you this is possible. This person did a complete teardown:
https://www.youtube.com/watch?v=WrMbmV2d...
The drive is under the door in the middle of the laptop.
Regards,
Dane K. Johnson
by
Add a comment
Add your answer
seanwp2 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 15
All Time: 3,364
