The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 Questions View all
Can't find a chat headset which works
i have bought several chat headsets which were all recommended for the xbox one s however none of them seem to work. they work with a normal xbox one but not the one s.
i have even had the console replaced incase that was the problem but the headsets do not work with the replacements either. please help x
Add a comment
Try this.
http://www.bestbuy.com/site/microsoft-xb...
1 Comment:
hi, that is the headset i bought but it will not work on the one s . tried on several one s consoles and it doesn't work but it does on a normal one console. thanks though ..
by
Add a comment
You should consider buying; the generic one at Gamstop/EB Games. If they faill to work I would consider seeing the controllers headset port as the issue. Try using one that you have, around the house or purchasing a new one, or attempt to fix it yourself via dissabembly (do not attempt if not confortable doing it, or without knowledge)
Add a comment
Add your answer
geordierichardson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 11
All Time: 96
