Why are none of my HDMI inputs working?
Manufacturer: Mitsubishi
Model: WD-Y57
Manufacture Date: August 2006
Firmware Version: V33Y 008.01
Issue:
Neither HDMI input displays the source connected to it, instead showing a blue screen.
History:
I initially received this TV from a friend who's workplace didn't want to bother selling the TV, so sadly I can't speak to what ultimately preceded the HDMI inputs not working. When I received it I noticed that neither HDMI port was working, and both just displayed blue screens. However the component and DVI inputs all worked so I opted to just use those.
After research on the internet, I discovered the likely culprit was the mainboard. After looking at the HDMI ports with a flash light I confirmed that the HDMI inputs themselves actually appeared damaged (bent pins, pushed back into the connector). So I went to eBay and ordered a board that was listed as confirmed and tested working.
Once the board arrived, I downloaded the service manual for the WD-Y57 and followed the instructions to replace the mainboard (including migrating the PWB-E2B from the old mainboard to the new one, and then copying the light engine E2PROM to DM and WB alignment to FMT). However after reassembly I appear to be in the same situation. Both HDMI ports still display blue screens.
Service manual in hand (https://www.manualslib.com/manual/800881...), I opted to:
1.) Reset user settings via INPUT & FORMAT on the front of the TV.. Still no joy.
2.) Reset all settings via hidden menu (MENU -> 2470 -> Initialize).. Still no joy.
3.) Reset all user settings via hidden menu (MENU -> 123).. Still no joy.
Very strangely, after doing the above resets the TV will see that an HDMI device is connected to a given HDMI port via the Input Auto Sensing feature, however when you switch to that input it's just a blue screen.
So now I'm stumped. Is the replacement board that I ordered defective? Is there something else I'm overlooking. I checked the wiring diagram in the back of the service manual and the only thing I see is that the HDMI input is processed by IC2004 HDMI Select -> IC2000 HDMI Proc.. But I'm unsure how to test if either of those are functional.
I'm using a Playstation 4 which works on two other TV's and an XBOX One which works on two other TV's to do my HDMI testing. I've tried three different cables which all work on the other two TV's.
Question:
Is my new mainboard defective? Or am I overlooking something?
