Color problem with nes
Please help. I recently bought a few Nintendos original. Problem - I load game for example Mario game starts looks fine. Soon as it starts the screen starts to constantly flash several different background colors. Blue green burgundy purple red. But i can play through tbe levels. I took console apart cleaned the 72 pin connector and connection on motherboard. Also adjusted tightened. Also disabled nes 10 and cleaned cartridges and changed video cables. Same problem. Cant find a solution answer anywhere online. Any info appreciated.
1 Comment
Is this problem happening for any game you try to play or just the one listed?
by
Add a comment
Most Helpful Answer
Hi Don,
Place the game you want to play in the NES. Once the game is in the NES and seated, place another cartridge inside the NES above the one you want to play. Once the 2nd cartridge is wedged in there the game you want to play will be forced down onto the pins and you will not experience this issue again.
Regards,
Dane K. Johnson
Score 1
1 Comment:
I'd recommend that you do not share tips if you do not understand the problem.
by
Add a comment
Most likely a problem with either the PPU chip in your nintendo or on the video output side. I'd open it up and check to see if it's clean in there. 75% of the consoles I've fixed have some pop drink spilled onto it. I'd clean that area, if not I'd reflow (resolder) the pins on the ppu. If that doesn't work it could also mean some bad caps.
Add a comment
Add your answer
Don will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 3,061
