IR Sensor on Vizio E470-A0 TV
Does anyone know if you can replace the Ir sensor on this particular model. Having a hard time finding out
Hi,
Is this the part that you require?
Scroll down the page to see if your TV's full model number is on the compatible TV list for this part or check the part number on the IR sensor board in your TV against the part number shown in the link.
Is there a way to find the ir model # without opening my tv?
Are you asking about replacing the sensor board (which includes the actual sensor) or just the actual sensor itself? If the former, you can order the board by the model number of your set. If the latter, these are readily available and are generic based upon the case type. I stock 3 different ones for example which have different looks.
Swapping the board will be easier. Swapping the part will be cheaper.
BTW: What makes you think that this requires replacement. This is not a common failure part.
Dan
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,057
1 Comment
Hi there. I have a vizio E470-A0 flat screen tv. I tested the remote and see the light flashing thru my cell phone camera. But it doesn’t turn on my tv. I have to do it manually and the volume also has to be done manually. I can change the channels using cable box remote thru the cable box . Should I change the IR sensor. And if yes, what is the item #?
by Chris
