Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
not responding screen black screen
hello,
i have bought new screen with the digitizer .. i had the iPad ready before the screen arrived it was working perfectly all i had to do is connect the cable for the new screen on the iPad and I'm done! what i didn't see coming is that the screen did not respond! its black i thought something must be not right with the screen so i plugged the old screen to check and it tuned out to work perfectly!!! when i tried with the new screen it still black and after a while the old screen didn't respond as well the new one either black or with lines .
what can i do ? what to replace etc!
Update (01/19/2017)
this is the screen
1 Comment
are you replacing the digitizer or the lcd? did you disconnect the battery prior to replacing?
by
Add a comment
1 Answer
Most Helpful Answer
this lcd display in pic is shot. you will have to replace it with more care as the lcd panel is extremely fragile
Score 1
2 Comments:
the problem is i bought it from the website and it came to me in the pic you see
by
hi Maryam then this has likely to have happened in the post due to the fragility of the LCD crystals in the display. it is not uncommon for us repairers to lift a lcd display working and replace it finding it damaged even with the up most care being used. the replacement will solve your issue thought and isolate the battery prior to replacing the display
by
Add a comment
Add your answer
maryam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 271
