Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1500 Questions View all
No contact with dock connector and no charge?
I have replaced the battery, AND the dock connector.
Unfortunately, my iPhone 3G is still not charging (computer & wall charger) nor is it being recognized when connecting to a computer (both MAC & PC).
Any ideas?
The reason for changing was just a drop, as far as I know there is no water damage.
Comments:
Yes, I have checked with multiple different cables.
by
what's the reason for swapping the parts? is it water damage or a fall? or just generally not charging?
by
Add a comment
Chosen Solution
replace again... doesn't work, motherboard issue.
Add a comment
Most Helpful Answer
have you checked the cables for charger/USB?
Score 2
Comments:
a drop wouldn't kill the battery. Could be damage to prongs on battery but it should be ok. Try swapping it back to see whether the new battery is the problem(sometimes happens)The clue to what's broken will be in the area of the external damage-obviously- so if connector 4 isn't damaged then I'd take a good look at the top left of motherboard under the metal cover to see if power processor is damaged.
by
Add a comment
Add your answer
jet75 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 999
