Clicking sound when I start waaher
When I first turn on my washer I hear a repetitive clicking sound.It runs through the cycles but I hear the sound again towards the end of the wash.Cant figure out what it is?Thanks Dave
Dave, there could be a few things making a clicking sound. First check inside machine to see if something is caught in between the outer drum and inner baskets mesh/holes, like a pen or hair pin, etc. remove if one found. Other things that could make clicking noise are worn drive belt, worn damaged pulley, bad transmission gear, clutch, relays, something stuck in pump, etc., etc..
Best to try and isolate the noise to see what area to inspect. You may have to tear the machine down a bit to locate the problem. Find a link below, the service manual to enable you to trouble shoot your machine. Good luck.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 53
All Time: 7,957
1 Comment
Dave did you figure this out? I'm having the same issue, it sounds like it's coming from the pump and I hear it before the drum starts to move.
by crazymominkansas
