Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Screen causes iPhone 5c to bootloop
i just did a screen replacement on my iPhone but the phone only works when the screen is hanging off, because when i push the screen down all the way it boots up my phone with out me even touching the power button and puts it into a boot-loop, what should i do maybe i am pinching a wire or something help please.
Add a comment
1 Answer
If the phone works fine when the screen is not installed in the frame but boot loops when installed in the frame, that is because you have some broken wires in the flex cable that when bent are causing a short circuit. The phone is boot looping because it is recognizing the faulty screen. Get a new screen and it should solve the problem. A good way to test if it is the screen is, if your old screen still works and just has broken glass, reconnect the old screen and install it and see if it works. If your phone boots up properly with the old screen, then you know you have a bad screen.
Add a comment
Add your answer
connor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 113
